Re: Pietenpol-List: Glue quantity to buy---and T88 information.
Posted: Thu Dec 06, 2001 8:20 pm
Original Posted By: "gbloud"
Greg Cardinal & Group,I was relieved to find that T88 has an indefinite shelf life be-cause I have had a couple of plastic bottles of it for a long,long time. I had been reluctant to use it for aircraft work, andhave restricted its use to other applications. I understand that the word "indefinite" means "unlimited". Is this the case?One thing I have noticed, however, is that the lighter coloredcomponent (the bottles are not handy as I write this, so I don'tknow which component it is) tends to granulate over time, par-ticularly when kept in a cool place. Immersing the container in hot (about the temperature it comes from the tap) water willrestore it to a molasses-like consistency, which seems to benormal. The other component, which has a brown color, doesnot tend to change over time, although placing both containersin moderately-hot water makes mixing the components a loteasier.I bought this T88 from Wicks about 15 years ago and it still works well on anything I stick together. I haven't used it on any aircraft stuff for at least ten years because I always thought it must have a shelf life---although there are no dates on the la-bels I have. A lot of adhesives do have a definite shelf life andthis led me to believe T88 would, too.Thanks for this information.Graham Hansen________________________________________________________________________________
