Pietenpol-List: Capstrip which is too thin
Original Posted By: john e fay
Jim wrote:>I could sure use some help and suggestions on installing shoulder>harnesses & seat belts for both front and back seats on a GN 1 with>a metal tubing fuselage.There are/were some excellent photos of how the Brits are doing the passenger cockpit shoulder harness attachment, per their PFA requirements... but I don't remember where the site is (big help, huh?). They use a welded bracket mounted to the top longerons, braced backwards, and concealed in the top cowl that covers the instruments.The pilot's shoulder harness attach that I've seen is just the cables running back to the tail inside the turtledeck, but steel tube fuselage sure gives you a lot more options than wood. You can see the few photos I have of belt attachments at http://www.flysquirrel.net/piets/piets3.htmlOscar ZunigaMedford, Oregonmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Date: Sat, 5 Jan 2002 12:18:56 -0600Subject: Pietenpol-List: Capstrip which is too thin
