Pietenpol-List: NX770CG
Posted: Wed Jan 09, 2002 3:32 am
Subject: Pietenpol-List: NX770CGPietenpol Aircamper - Model A engine (bored .060), Wico Mag model X, short fuselage, tail skid (no brakes), Stits covering system (2.7oz on wing & fuse - 1.8oz on empenage & ailerons), fiberglass fuel tank (no alcohol allowed), home built birch prop with Kevlar / fiberglass tipping (74 X 48), 3/4" douglas fir spars and longerons, spruce empenage, cedar ribs, shoulder harness to the tail post, Rustoleum Oil base Enamel aluminum paint #7715 (red fuselage w/ white stripe and silver wing w/ red starburst on top), Ace Spar Varnish (pt #16375), 674 pounds, radiator is width between cabanes and about 12" tall with top tank recessed in behind the leading edge, cowling is .025 2024 epoxy primer / red paint, detailed photo log and airframe / engine log, W&B taken care of by moving wing back 3 1/2" and 14 pound ballast (I weigh 200 lbs. after a bowel movement), E.W.C.G. is 12.61" behind leading edge, engine problems taken care of - was ready for final inspection 2 months ago. Couldn't have done it without my partner, Doug Bryant !! Thank you Doug !!The FAA guy called me this morning, at 8:30, and agreed to meet me out at Benton Airpark for the final inspection. After over 2 hours of close inspection, and almost an hour of paperwork...I've got my AIRWORTHYNESS CERTIFICATE !! He paid many complements on workmanship & design...I've almost got him talked into building one !!Stay tuned...first flight coming up !!Chuck GantzerWichita KSNX770CG________________________________________________________________________________
