Jim Kinsella and others,My Pietenpol is powered by a Continental C85. Early on ithad an A65.The VSTAB is rigged without offset because of its small areaand a rudder tab, when I used it, easily corrected the left yaw in cruise with either engine installed.Some day I may re-install the tab, but in my opinion it isn't real-ly necessary because I don't fly long trips and our air is rarelysmooth enough to notice its effect.Mounting the engine with some right side thrust was consideredbut I never got aroung to trying that option. Has anyone out theretried the side thrust idea on a Pietenpol? Some a/c use it togetherwith downthrust (I don't use either on my Piet).Cheers,Graham Hansen (CF-AUN)________________________________________________________________________________
Re: Pietenpol-List: VSTAB alignment (addendum to my earlier post)
Original Posted By: "Larry Ragan"
Mounting the engine with some right side thrust was considered but I never got aroung to trying that option. Has anyone out there tried the side thrust idea on a Pietenpol? Some a/c use it together with downthrust (I don't use either on my Piet). Cheers, Graham Hansen (CF-AUN)***************************************************************************************** My Piet has an 0-200. When I first flew it with engine aligned to thecenterline of the airplane it was a bear. I had a problem keeping itstraight & level. Don't ask about the landing. I tilted the engine tothe right & down by inserting shims between the engine & engine mount.After that, it almost flys hands off ( in smooth air ). Mike B Piet N687MB ( Mr Sam )________________________________________________________________________________
Re: Pietenpol-List: Plywood gussets
Original Posted By: "D.Dale Johnson"
hiatus from things aviation related, I am happy to say that I'm back in the Pietenpolafficianado fold. Hopefully the same enthusiasm that existed 2 years agofor the Piet hasn't waned, and I can now follow up on my intentions to maybeeven get started on my own project.I havenoticed some of the same names in the discussion list. The famous MichaelCuy, and others. In addition, I've noticed quite a few new (in the last 2 years)people which gives mehope that maybe there is someone at the same point (notstarted yet) as I. I probably will depend a lot on the list to not only directme in the right directiontechnically,but also to keep your enthusiasm andencouragement constant.My intentions are to build a 'Vair powered Air Camper with a 3 piece wing, andmaybe even make some width and length modifications. Nothing drastic....just withinthelimits of what has already been done andtested. Any suggestions pro orcon? Anythingdrastically changed over the last couple of years?Are thesuppliersofplans (D. Pietenpol), modifications (3 piecewing), supplies, the same?Anyway, glad to be back. I look forward to reading the comments on every thingin this message board.Larry Ragan Jacksonville, Fl. lragan(at)hotmail.com Send and receive Hotmail on your mobile device: Click Here________________________________________________________________________________Date: Thu, 17 Jan 2002 21:00:18 -0600Subject: Re: Pietenpol-List: Plywood gussets
