Original Posted By: clif
Pietenpol-List: bufoonery
Re: Pietenpol-List: info-naca
Original Posted By: "clif"
I tried the link with no results. Anyone else?Chris Bobka----- Original Message -----
Re: Pietenpol-List: bufoonery
Original Posted By: JamesJboyer(at)aol.com
Subject: Re: Pietenpol-List: bufooneryHello there ,I have built most of the Piet so far and just mixed it well, a couple of minutes, and made test pieces with each batch. The ones that I have broken apart to check the glue joints have all torn the wood apart NONE OF THE GLUE JOINTS HAVE SEPARATED. You don't need to mix it until your arms/fingers/whatever is sore! Use common sense and think about what you are doing.Cheers, JimPS the rocket science is all in the formulation of the glue; not the gluing!________________________________________________________________________________
Original Posted By: "Tom & Michelle Brant"
Subject: Re: Pietenpol-List: info-nacaHi Gary,Sounds like you have all the right things listed, but I would like to make a suggestion about order!1. Wife2. Wife3. WifeIf you can do these three the rest will fall in line no sweat and probably with her willing help.Cheers, Jim________________________________________________________________________________Date: Fri, 25 Jan 2002 23:23:20 -0800
Try this one, it gets you to the NACA page, pick where you want to go fromthere.http://naca.larc.nasa.gov/Doug Blackburn, Arrowbear Lake, So. Cal.Inland Slope Rebels, Riverside Ca.________________________________________________________________________________Date: Fri, 25 Jan 2002 23:30:11 -0800
Pietenpol-List: 12 hours door to door
Original Posted By: Fisherman Caye
> Pietenpol-List: T-88 Bafoonery
