Pietenpol-List: Capstrip ripping
Posted: Mon Jan 28, 2002 1:18 pm
I spent Sunday afternoon ripping my capstrip material, and I'd likesome opinions about the process and finished dimensions. I'm usingWestern Red Cedar 1 x 8" x 8' , and I attached a plywood straight edge onthe boards and ripped both sides to a nice straight edge. Then with mytablesaw fence set to 1/4" (measured from the blade) I started . My sawblade was parallel to the fence. As I progressed thru the board, I foundthat one end became narrower than the other end. The last cut had the boardjust over 1/4" at the front and about 5/8" at the back, when it started outat 5" both ends. Something was wrong, but I don't know what. Any ideas? It seemed hard to get a consistent 1/4" width the complete length ofthe capstrip. At various places the capstrip would measure + or - about1/64th to 1/32 from the 1/4" I wanted. Should this be a major concern? I'mhoping the sturdiness of the design will help me out here. I checked the archives in rec.woodworking and rec.boatbuilding andthere are differing opinions about having the thin strip against the fenceor on the outside of the cut. One way has the fence set once, the secondway has you moving the fence for each cut. I had the capstrip against thefence. Kent Hallsten . ________________________________________________________________________________
