Pietenpol-List: reply to John McNarry-model a torque
Original Posted By: Fisherman Caye
RE: Pietenpol-List: reply to John McNarry-model a torque
Thanks Cliff. Tried that site yesterday but no avail. I have a B extensively modifiedalready.It has my own design oilpan and timing gear cover that allows the use of aSubaru oil pump and filter, driven from a gear running off of the bottom ofthe crank gear. The crank is drilled and I am now designing a new inductionsystem. I intend to mount an SU carb below the oil pan flange on the rightside. A tube carries through the pan under the center main and as it exits,it curves up splitting in two to feed the intake runners. The hope is to getthe pulse length right so that it will take advantage of the ram effect ofthe runners. I have a dyno built in anticipation of the running. If Iremember the specs from that BPA article the Brumfield head gave the bestperformance. Anyone know who still makes a copy? Is Dan Price still castingheads?John-----Original Message-----
