Pietenpol-List: McNarry question
Posted: Sun Feb 03, 2002 8:34 pm
John,Any vertical surface area forward of the Center of Pressure will tend todestabilize. This is why we see floatplanes with additional verticalsurface area aft to offset the destabilizing effect of the float's verticalsurfaces forward, the majority of which are forward.Since the A-65 is lighter than the Model A, it is imperative that the motorbe mounted farther forward to keep the ship in balance. The additionalcowling area needed will destabilize. Those that have used the spokedwheels that are fabric covered have also noticed(complained) about thedestabilizing effect.A fix would be to build slightly oversize vertical stab and rudder, moresothe stabilizer. No one would really notice and you would have a sweeterflying ship. This would have to be worked into the design from day one ofthe fuselage build up.Chris BobkaTech Counselor-----Original Message-----
