Pietenpol-List: Pitot tube and static tube
Posted: Tue Feb 05, 2002 9:53 pm
Jack,Are you sure that your static tube did not break off your pitot tube? Onthe 140 I fly all the time, it has a nice pitot static setup that comes downout of wing (the fabric wing) and the pitot and static are siamesedtogether.The wing probably has the lowest pressure inside it in the entire ship.It seems one could make a nice pitot and static setup from some coppertubing. I am sure it is covered in Bingelis somewhere. In my opinion, theoutboard wing location down and forward a foot or so is the best. If thestatic tube has but two holes in it, one left and one right with themlocated on the horizontal axis, any slipping will be nulled out by thepressure going up on the windward side and the pressure dropping on theleeward side and the net will still be as close to the true static pressureas you can get.Finding a spot on the fuselage that is proper would take some sensitiveinstrumentation.My tcraft had open static ports to the inside of the cabin and I flew slowerthan indicated and I always knew I was lower than the altimeter said butthat is ok if you are under class B.chris bobka________________________________________________________________________________
