Pietenpol-List: Zinc Chromate Primer
Posted: Sat Feb 09, 2002 9:24 am
Zinc Chromate primer is sprayed lightly (wet, about 1,000 square feetper gallon) on aluminum and steel aircraft parts. It is the best,time-proven primer to prevent corrosion and rust in all applications.Available in green and yellow colors, it also provides maximum adhesionfor subsequent paints.Zinc Chromate primer is also made in epoxy form for use on steel tubeairframes that will be covered with fabric.Gene VickeryTehachapi, CA________________________________________________________________________________
Posted: Sun Feb 10, 2002 2:46 am
Original Posted By: clif
RE: Pietenpol-List: Zinc Chromate Primer
Posted: Sun Feb 10, 2002 9:39 pm
I have read that Alkyd Enamel paint is dope proof. Chris Bobka-----Original Message-----
Re: Pietenpol-List: Zinc Chromate Primer
Posted: Sun Feb 10, 2002 9:45 pm
Subject: Re: Pietenpol-List: Zinc Chromate PrimerIn a message dated 2/10/02 7:40:10 PM Pacific Standard Time, bobka(at)charter.net writes:> I have read that Alkyd Enamel paint is dope proof. > > Chris Bobka> > Chris, I use ACE oil based spar varnish (not polyurathane) with excellent results. Doug Bryant ________________________________________________________________________________
Posted: Sun Feb 10, 2002 10:04 pm
Home depot was closing out their Behr brand alkyd enamal and I bought about12 quart cans in grey and white. Still need to do a test.Chris-----Original Message-----
