Pietenpol-List: Re: Leading edge question.
Posted: Thu Mar 07, 2002 9:44 pm
Pieters:I am using aluminum for my leading edge on my center section (GN-1). Thetop and bottom, from front spar to rear spar is 1.5 mm plywood. When I wrapthe aluminum around the leading edge and pull it back to mate up with theplywood on top (and on bottom), is it ok to just lap it over approximatelyon top of the front spar. (Likewise on the underside) Or do I need to tryto carefully cut a layer of the tiny ply down so the aluminum will lay inand mate up (butt up to ) the plywood. i guess my question is how perfectdoes the aluminum -to- plywood transition need to be to be able to cover thewhole thing with fabric and not have it look like a bag of marbles?Is it adviseable to use aircraft nails or could I use screws to attach thealuminum to the plywood?Any help is appreciated! Thanks, bert________________________________________________________________________________
