Re: Pietenpol-List: Stick with the list guys.........
Posted: Sat Mar 09, 2002 7:06 pm
----- Original Message -----
Pietenpol-List: Re: Horn fabrication
Posted: Sat Mar 09, 2002 8:10 pm
Original Posted By: catdesigns(at)juno.com
Subject: Re: Pietenpol-List: Stick with the list guys.........In a message dated 3/9/02 5:07:58 PM Pacific Standard Time, bconoly(at)earthlink.net writes:> Question of the day..... I need to paint some wing fittings, cabane> struts, and other KEYparts. Some are unreachable for inspection. Is there> really any reason why I cant use a good quality automotive primer? Of> course my plane will be hangared... I just HATE having to order Zinc> Chromate..> But if I have to I will.> > bert> > > Bert,My humble opinion; In my A&P program years ago, we used Zinc Chromate only for aluminum after an Alodine and etch treatment. I paint all my steel parts with spray can primer followed by a color top coat of spray can paint or brushed on oil based enamel and it seems to hold up fine for me. Doug Bryant________________________________________________________________________________Date: Sat, 9 Mar 2002 18:24:48 -0800Subject: Pietenpol-List: Re: Horn fabrication
Posted: Sat Mar 09, 2002 8:30 pm
Original Posted By: Kirk & Laura Huizenga
Original Posted By: Bert Conoly
Posted: Sat Mar 09, 2002 8:39 pm
Original Posted By: clif
Posted: Sat Mar 09, 2002 8:40 pm
Doug. Is that just a common auto primer such as one would get at a autosupply store? Heretofore I have used regular old spray primers for landinggear, controls, etc. But they are easily inspected and accessible. I guessI am sensitive to Spar fittings etc that you cant get to to check thecondition easily. I THINK I am feeling better about just using anautomotive primer and be done with it.(SEE...... That's why I'm still here!)Thanks, bert (from Tallahassee where we've seen and absolutely beautiful daytoday.)----- Original Message -----
Posted: Sun Mar 10, 2002 5:37 pm
Subject: Re: Pietenpol-List: Stick with the list guys.........In a message dated 3/9/02 6:41:24 PM Pacific Standard Time, bconoly(at)earthlink.net writes:> Doug. Is that just a common auto primer such as one would get at a auto> supply store? Heretofore I have used regular old spray primers for landing> gear, controls, etc. But they are easily inspected and accessible. I > guess> I am sensitive to Spar fittings etc that you cant get to to check the> condition easily. I THINK I am feeling better about just using an> automotive primer and be done with it.> > Bert,I just use the common stuff from the hardware store. It holds up fine especially inside the wing where it is not subjuct to any elements. Ofcourse there will be inspection rings where the fittings are. A friend is building a Piet here and he has powder coat equipment which is another way to get permanent finishes. Doug Bryant________________________________________________________________________________
Posted: Mon Mar 11, 2002 4:09 am
Posted: Fri Mar 15, 2002 9:15 pm
Original Posted By: "Bert Conoly"
Bert, most of the Automotive paint suppliers in my area also stock zincchromate. You might try your local supplier.Phil Phillips----- Original Message -----
Posted: Sat Mar 16, 2002 6:09 am
