Pietenpol-List: Mixing Epoxy
Original Posted By: "Ed Grentzer"
Doug Blackburn has a good idea in using a digital scale to get accuratemeasurements when mixing epoxy. Those using T-88 should remember,however, that while the correct resin-to-hardener proportion is 1:1 byvolume, it is 1:0.83 by weight.Ted Tuckerman________________________________________________________________________________
Re: Pietenpol-List: Mixing Epoxy
Original Posted By: ws133b341
Ted, I never considered that wieght aspect of it before. Does the hardnerwiegh more or the resin? If they are the same, would'nrt the ratio remainthe same? Thanks for bringing that to our attention.Doug B.Doug/Elizabeth BlackburnArrowBear Lake Ca.Inland Slope Rebels, Riverside Ca. http://inlandsloperebels.com----- Original Message -----
Original Posted By: "TWINBOOM"
Doug:The T-88 resin is a bit heavier (has a higher specific gravity.) For moreinfo, you can view the technical data sheet and Material Safety Data Sheet(MSDS) at the manufacturer's web site: www.systemthree.comTed----- Original Message -----
RE: Pietenpol-List: Mixing Epoxy
Original Posted By: "MORGAN HETRICK"
Thanks for this link and the suggestion about using the scale. My wife hasa Weight Watchers digital scale, so guess where that dust collector is goingto be now?Kent HallstenOklahoma City________________________________________________________________________________
