Pietenpol-List: Mixing Epoxy
Posted: Wed Mar 13, 2002 7:10 pm
Original Posted By: "Ed Grentzer"
Doug Blackburn has a good idea in using a digital scale to get accuratemeasurements when mixing epoxy. Those using T-88 should remember,however, that while the correct resin-to-hardener proportion is 1:1 byvolume, it is 1:0.83 by weight.Ted Tuckerman________________________________________________________________________________
Re: Pietenpol-List: Mixing Epoxy
Posted: Wed Mar 13, 2002 8:27 pm
Original Posted By: ws133b341
Ted, I never considered that wieght aspect of it before. Does the hardnerwiegh more or the resin? If they are the same, would'nrt the ratio remainthe same? Thanks for bringing that to our attention.Doug B.Doug/Elizabeth BlackburnArrowBear Lake Ca.Inland Slope Rebels, Riverside Ca. http://inlandsloperebels.com----- Original Message -----
Posted: Wed Mar 13, 2002 10:09 pm
Original Posted By: "TWINBOOM"
Doug:The T-88 resin is a bit heavier (has a higher specific gravity.) For moreinfo, you can view the technical data sheet and Material Safety Data Sheet(MSDS) at the manufacturer's web site: www.systemthree.comTed----- Original Message -----
Posted: Wed Mar 13, 2002 10:37 pm
RE: Pietenpol-List: Mixing Epoxy
Posted: Thu Mar 14, 2002 7:49 am
Original Posted By: "MORGAN HETRICK"
Thanks for this link and the suggestion about using the scale. My wife hasa Weight Watchers digital scale, so guess where that dust collector is goingto be now?Kent HallstenOklahoma City________________________________________________________________________________
