Pietenpol-List: Ignition Wiring
Posted: Fri Mar 15, 2002 10:44 am
Original Posted By: "hallstenokc"
Question about wiring up my ignition switch: I'm using shielded P leads(and a shielded ignition harness) so I can use a handheld radio if necessary(like for my first flight). Do I need to run a separate ground wire to theground post on the ignition switch, or can I just terminate the braidedshields at the ground post on the switch and at the engine. Will that makean effective ground? I hate to have to run more wires than necessary - theyadd weight and work, and I'm very lazy.Jack Phillips________________________________________________________________________________
