Pietenpol-List: Glue clean-up
Posted: Sun Mar 17, 2002 8:03 pm
Denatured alcohol is the thinner and cleaner-upper for T-88. Only workswhile the glue is not yet hardened, but does a dynamite job. After it'shardened, use a wire wheel on the grinder!Vinegar is great for silicons or the Tite-Bond II types. Soap and water forElmer's.CraigWishing there was a clean-up solvent for welding!________________________________________________________________________________
Re: Pietenpol-List: Glue clean-up
Posted: Sun Mar 17, 2002 8:30 pm
Subject: Re: Pietenpol-List: Glue clean-upIn a message dated 3/17/02 8:59:36 PM Eastern Standard Time, craigwilcox(at)peoplepc.com writes:>What about good old Finger Nail Polish Remover ? Its acetone based.________________________________________________________________________________
RE: Pietenpol-List: Glue clean-up
Posted: Mon Mar 18, 2002 8:55 am
Original Posted By: "Mark"
Just wondering, is there a reason to thin T-88 for a Piet? My mix seemsbuttery and goes on pretty good, drips pretty good too. Is T-88 the sameepoxy the fiberglass builders use on the lay-ups? I can see that beingthinned out to brush on. When I leave my T-88 in the garage and it gets toocold, I zap it in the microwave for a minute to thin it. I found that the wife's weight watcher digital scale requires a good amountof glue in order to get a reading. Wasteful. So it's back to smallerbatches by eye.Kent HallstenOklahoma CityFinally got some rain!Denatured alcohol is the thinner and cleaner-upper for T-88. Only workswhile the glue is not yet hardened, but does a dynamite job. _________________________________________________________________________________
>>Just wondering, is there a reason to thin T-88 for a Piet? My mix seems>buttery and goes on pretty good, drips pretty good too. Is T-88 the same>epoxy the fiberglass builders use on the lay-ups? I can see that being>thinned out to brush on. When I leave my T-88 in the garage and it gets too>cold, I zap it in the microwave for a minute to thin it. I have not seen it used for fiberglassing - SystemThree makes other products tooto do that type of stuff. You can thin and use it as a sealer on your wood -or so I have heard. I would imagine it would work well.>>I found that the wife's weight watcher digital scale requires a good amount>of glue in order to get a reading. Wasteful. So it's back to smaller>batches by eye.Some good scales are listed in the Tools>>Contruction Equipment area of this site. http://www.lancair-es.com/.Gary McNeel>>Kent Hallsten>Oklahoma City>Finally got some rain!>>>>Denatured alcohol is the thinner and cleaner-upper for T-88. Only works>while the glue is not yet hardened, but does a dynamite job. >_>>________________________________________________________________________________
Original Posted By: "Mike"
> >Just wondering, is there a reason to thin T-88 for a Piet? My mixseems >buttery and goes on pretty good, drips pretty good too. Is T-88 thesame >epoxy the fiberglass builders use on the lay-ups? I can see thatbeing >thinned out to brush on. When I leave my T-88 in the garage and itgets too >cold, I zap it in the microwave for a minute to thin it. I+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ This is a tip form Steve's former list: "A simple solution to warm your epoxy regularly, you can build a cheap warmer box out of Celotex board and duct tape. Put atemperature switch in it from a farm supply like the ones used in incubators. Hook a lightbulb to the switch and your epoxy will reach and stay at just theright temp all the time". Mike B Piet N687MB (Mr Sam)________________________________________________________________________________
Posted: Mon Mar 18, 2002 2:52 pm
Original Posted By: Gary McNeel, Jr.
----- Original Message -----
