Re: Pietenpol-List: Skimpy fittings.
Posted: Tue Apr 23, 2002 1:35 am
Jack Phillips and others are correct in stating that, as designed,the Pietenpol fittings are too small in some dimensions. This cancause difficulty when installing bolts because things get too tightin corners (eg. at landing gear/lift strut fittings inside the fuselage).I enlarged quite a few fittings when I built my Pietenpol. Luckily, Ibuilt the wooden components first and it became obvious that I was going to be in trouble if I followed the plans when making the fittings. Had I done so, the bolts attaching the landing gear fittingswould have gone through the lower longeron---something I didn't like. So I lengthened the fittings enough to allow the bolt holes torun through the corner blocking thus missing the longeron and pre-serving its full cross section. I could have lengthened them a bit more than I did because things are still a bit tight inside the fuse-lage. As Jack suggested, the 5/8" brace wire fittings are a bit skimpy. I made mine 3/4" wide for the same reasons he stated. All fittings have been satisfactory for literally thousands of takeoffs and landings from pretty rough airstrips.A recent post mentioned the possibility of publishing a plans sup-plement with patterns for the modified fittings---perhaps by thePietenpol family. This is an excellent idea.In the meantime, I would recommend building the major woodcomponents first and then make the steel fittings to suit, using the original plans as a guide.Graham Hansen (Pietenpol CF-AUN) .________________________________________________________________________________Date: Tue, 23 Apr 2002 12:34:45 -0400
