Pietenpol-List: Gusset trimming
Posted: Wed May 08, 2002 8:46 am
How are you trimming the bit of gusset that overhangs the capstrip? Do youuse a router/table combination or a Dremel type tool? Big file andArmstrong method? Sandpaper blocks?Kent Hallsten________________________________________________________________________________Date: Wed, 08 May 2002 08:54:52 -0500
RE: Pietenpol-List: Gusset trimming
Posted: Wed May 08, 2002 9:09 am
Original Posted By: Greg Cardinal [mailto:gcardinal(at)startribune.com]
What kind of bit on the router?-----Original Message-----
Re: Pietenpol-List: Gusset trimming
Posted: Wed May 08, 2002 9:34 am
Posted: Wed May 08, 2002 9:41 am
Original Posted By: "DJ Vegh"
Subject: Re: Pietenpol-List: Gusset trimmingPieters,I did an additional little operation on my rib gussets. Since building sailboats years ago, LIghtning Class, I drilled small holes in all the lower gussets, each side, where moisture could condense and in time rot. Won't weaken anything but might help on the moisture bit but I wouldn't even suggest any weight saving factor.Corky in humid La still waiting to hear from the Fedman . ________________________________________________________________________________
Posted: Wed May 08, 2002 9:47 am
I'm using a laminate trimmer with a bearing flush cutter. trims an rib inless than 20 seconds.DJ VeghMesa, AZGN-1/Piet hybridwww.raptoronline.com N74DV-----Original Message-----
Posted: Wed May 08, 2002 10:19 am
