Re: Pietenpol-List: Seat Stuff & Fuel Tank
Posted: Thu May 16, 2002 12:34 pm
Original Posted By: Mike Hardaway
On Wed, 15 May 2002, Larry Neal wrote> But what to do, should I weld it in steel, or $Pay$someone to weld in > aluminum? Sorry, I just can't bring myself to put ina fiberglass tank. > No-way, not this airplane...Larry - get some .050 or so 5052-H32 aluminum and makethe tank from that. It is remarkably easy to cut andform into what you want, leaving flanges where thepieces join. Check with the shop doing the welding -they may even have you pop rivet it together to makethe welding easier. Most shops will weld it up,including the filler neck, vent, and drain fittings,for a nominal fee. They will also pressure test it foryou - be sure to specify 3 psi or less! As they chargeby the hour, tho, do all the cutting and fitting beforeyou take it to them. I've done several tanks this wayand each has turned out to be everything I'd wanted. If you want a baffle, you can pop rivet it in withaluminum rivets - they weld right over them when theydo the whole thingCraigLake Worth, FLBakeng Duce NX96CWPeoplePC: It's for people. And it's just smart. http://www.peoplepc.com ________________________________________________________________________________Date: Thu, 16 May 2002 22:56:45 -0700
