Pietenpol-List: A good reason to use metal cans..
As corky just sent out, refueling is dangerous, even moreso when one uses aplastic container to pour from as it is very difficult to ground a plasticgas can. With steel, you can ground the can to the funnel to the tankbefore you start the pour but the plastic cans don't work the same way.There was a guy refueling is luscombe a few years back from a plastic canand the static discharged and lit up the vapors. He even had a ground strapto the can and to the aircraft and to the earth but apparently a potentialcan still exist from one end of the plastic can to the other. I have heardof other cases as well, especially with plastic bedliners in pickup trucksarcing over the side to the gas tank neck vicinity.Use steel cans...Chris Bobka________________________________________________________________________________
