Pietenpol-List: Re: Pietenpol- crank starters
Posted: Mon Aug 12, 2002 9:11 pm
Subject: Pietenpol-List: Re: Pietenpol- crank startersPieters,,, I need some help from some old timers or smart young guys. I have a A 75 - 9 continental motor which as the unusual starter pad that takes a 3 notch drive on the surface of a gear. I think they used this setup on old radials and maybe rangers engines. I was going thru the junk shop at OshGosh and I found a crank starter built by Eclipes which was a division of Bendix and thought I had hit gold. I knew it would fit and it does but IT TURNS THE WRONG WAY. This one turns clock wise from the pilots view. What I want to know is, can they be reversed or do they build counter clockwise and clockwise versions or does someone have one to trade. Any help would be appreciated or information where I can learn more.Ken Conrad. Long Grove, Iowa This is not a centrifucal type but just a side crank and wt is 11 lbs.________________________________________________________________________________
