Pietenpol-List: firewall for corvair
Posted: Sat Aug 17, 2002 12:59 am
Original Posted By: "Brants"
Re: Pietenpol-List: firewall for corvair
Posted: Sat Aug 17, 2002 11:47 am
Original Posted By: "The Huizenga's"
Posted: Sat Aug 17, 2002 11:57 am
Original Posted By: The Huizenga's
The manual I recieved from Wm Wynn did not have the motor mount plans.Hmmm, have to write him about that. I used the Pietenpol plans for thecorvairand put in the thrust line Bernie used.Kirk you are correct in securing the center tubes. All the weight issupportedin the corner mounts.Carl----- Original Message -----
Tom, Do you have Wynnes manual? If so, there should be a motor mount therefor a Corvair, I had one in mine.Doug BlackburnDoug/Elizabeth BlackburnArrowBear Lake Ca.Inland Slope Rebels, Riverside Ca. http://inlandsloperebels.com----- Original Message -----
Posted: Sat Aug 17, 2002 10:43 pm
Kirk, I agree, I believe the tubing behind the engine really doesn't doanything.It does help line up the tubes on the jig when welding, but gives no supportas faras strength goes. A friend of mine, Bill Poiry, did his with square tubingfor hisfranklin 65 ( which is the same mount as our corvairs) and it looked realgood.I ended up making two and I left the extra tubing on the final one.The mainthing is make sure the welds are solid.Carlps On my firewall, I just used metal at the top and when it is secured tothe cowlingit becomes very strong and rigid.----- Original Message -----
Posted: Sun Aug 18, 2002 2:10 am
Posted: Mon Aug 19, 2002 11:49 am
