Pietenpol-List: 1/4" x 1/8" filler
Posted: Tue Aug 27, 2002 3:17 am
Original Posted By: clif
Pietenpol-List: RE: 1/4" x 1/8" filler
Posted: Tue Aug 27, 2002 12:10 pm
Original Posted By: catdesigns(at)juno.com
Subject: Pietenpol-List: RE: 1/4" x 1/8" filler
Re: Pietenpol-List: 1/4" x 1/8" filler
Posted: Tue Aug 27, 2002 2:25 pm
Original Posted By: "Brants"
Tom,I found that if you made them as exact as you are talking about, the cornersof the body would be sharp like a razor. I made each strip even with theedge of it's longeron side, then when done used small sharp plane (no pun)or sanding block to give the edge a rounded look ( small round like a 1/8"radiis) then when the fabric and tape goes on, it looks good. But you canmake it a sharp as you'd like.walt----- Original Message -----
1/4" x 1/8" filler
Posted: Fri Apr 28, 2017 9:29 pm
Hey all,Just wondering what people have done about the filler strip betweengussetts... I noticed tonight when I put the bottom gusset plates on,that you pretty much have to leave a 1/8" overhang where the top gussetsaren't met by the side gussets.... Otherwise there will be a littleledge where the two gussets meet - if the top gussets are put on flushwith the longeron.... This make sense?? What have others done here?Tom Brant, MPLS________________________________________________________________________________
