Pietenpol-List: the -6 means you have a fuselage fuel tank?
Posted: Fri Sep 27, 2002 2:15 pm
Corky,Just making sure that you have a fuselage tank for fuel and no wing tank?That is why the -6?Also, if you can confirm this fuselage tank issue, I will compute most aftand most forward CG (worse case loading scenarios)and this could be noted onthe paperwork too. Have you proposed CG limits fore and aft?Chris________________________________________________________________________________
