Pietenpol-List: what about unuseable fuel?
Original Posted By: "TWINBOOM"
Corky,Have you determined a number yet for unuseable fuel or are you going to dosome climb with acceleration tests while airborme to determine the min fuelthat will still allow the engine to run?Need this for the aft most CG worst case scenario with near empty fuel and185 lb pilot and no passenger and 6 lbs of gloves in the glovebox.Forward most CG worst case is pilot and passenger and full fuel and nothingin the glovebox.Chris________________________________________________________________________________
