Pietenpol-List: Piet update
Posted: Sun Oct 20, 2002 9:08 pm
Friends-Some of you have asked for an update on my Piet since Brodhead so, here it is.I copied the intact half of John Greenlee's Ray Hegy prop onto my Red Oak/Mapleblank. John's prop was 76x44, mine is 2" shorter hence the pitch comes out abit higher. I have studied several sources about prop-building and can say withauthority that no two prop makers use the same data to arrive at their pitchnumbers. Some use half diameter, others use 2/3 diameter and some use the tip!!!Even the formulas that should be the one constant are interpreted differently.The point is; if you're looking for a prop, try to find what someone (or a lotof someones) are having success with and go with that. I measured my Falcon propthat was stamped 74x42 and the pitch came out to be 51" based on another sources'formulas!!!! Even the Sensenich at 44" pitch was more like 48". So whosefigures do you use? My advice is that unless you are willing to make severalprops, go with the crowd or copy a known quantity like I did.Now- the prop that I have made seems like it is a little better in the climb andcruises at a given speed at 50 rpm less than the Sensenich. Sounds like a winner,right? BUT the outside air temp is about 35 degrees cooler than when I flewto Brodhead so the jury is still out on performance until I can duplicatethe 90 degree days of summer. Of course by that time I should have a lot morehours on the "A" and that will help, too. I am very happy that I built (copied) my new prop. It certainly isn't any worsethan the two previous ones and it's one more thing that I can say is home-made.Makes me feel independent and "accomplished" but best of all, it gets me backinto the sky!Larryps. I found out that keeping the forward cockpit cover in place while flying (tryingto stay warm!) seems to create a lot more turbulence for the pilot. My nextstep is to take off the front windshield and see what effect that has.________________________________________________________________________________
