RE: Pietenpol-List: Piet AD on my (or your) brake system possibly
Posted: Tue Oct 22, 2002 8:15 pm
Original Posted By: clif
Thanks Mike! Will keep that in mind when I get back to my axle.JohnWhat happened is that after about 280 hours of flying the anti-torque tubesbroke off where they are weldedto the bottom of the axle. I believe that several factors contributed tothis. 1) I should have used thicker wall tubing for these parts. 2) Mytolerance between the "pin/tube" and the "collar" or tube sliding thru atube were too sloppy.3) every time you apply the brakes, the axle wants to rotate forward underthe bungee wraps. This is normal and is exactly what the anti-torque systemis designed to stop. (along with keeping your axel from moving left toright under the bungees when you make turns, etc.) This slight rocking orrotating slightly forward of the axle puts a flex load on thosetube-in-tube, anti-torque pins and bends them slightly. After thousandsof applications of the brakes this rocking, flexing, and bending createdenough slop so that the axle actually would rotate forward about 3/4" whenI would apply the brakes and thus make my brake cables too short andapplying more and more brake the more the axle rotated forward. I waswondering why my brakes were actually becoming increasingly more effective! Ha !Big dummy didn't figure it out in time so one day about 2 weeks ago whiledoing a run up the brakes wouldn't release and more power bent/sheard theanti-torque tubes right off. Make your tolerances tight and keep thepins greased.I think Carl Loar has a sketch of my system on his web site possibly if youcan't envision the system from the pics.Mike C.________________________________________________________________________________Date: Wed, 23 Oct 2002 19:35:30 -0700
Pietenpol-List: piet pics
Posted: Wed Oct 23, 2002 8:00 pm
TedThanks again for the ride in your Piet at Thomasville. It's given me a boost whileI am mounting my wing to the fuse. The pics are great.Dick________________________________________________________________________________
Posted: Wed Oct 23, 2002 8:10 pm
Hi Mike,Many thanks for the warning! I made my pins pretty thick (.058" wall) but Imight see if I can make them thicker, and I'll watch the slop. Did theyboth break at once? I would think that would be better than only onebreaking.Jack-----Original Message-----
Posted: Wed Apr 18, 2012 11:15 am
Original Posted By: "nightmare"
had a cub, sold it 10 years ago when lost previous flying job. actually won itin the usaerobatic foundation raffle. flew it from oshkosh to south florida. yourgonna make me cry now.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: piet pics
Posted: Wed Apr 18, 2012 11:39 am
just looking for maybe a link for a bunch of piet pics in one place. or maybe whoeverreads this can include their Piet pic. thanks; PaulRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 18 Apr 2012 09:54:35 -0700 (PDT)
Re: Pietenpol-List: piet pics
Posted: Wed Apr 18, 2012 11:57 am
http://textors.com/PietProject.html Jack TextorSent from my iPadOn Apr 18, 2012, at 11:39 AM, "nightmare" wrote:> > just looking for maybe a link for a bunch of piet pics in one place. or maybewhoever reads this can include their Piet pic. thanks; Paul> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 164#371164> > > > > > > > > > ________________________________________________________________________________
Posted: Wed Apr 18, 2012 12:00 pm
Original Posted By: "Sanders, Andrew P"
Subject: Re: Pietenpol-List: piet picsIf you wait till July you can get all the pics you want of any and every part you want in any power configuration you want. All you need to do is go to the Brodhead fly in. A field filled with Piets, Piet builders, wanna be fliers and liars. A veritable morgishgoard of Piets and Piets peoples Do not achieve this big secret This is flying weather, I can see by the number of people here today I'm gonna need lots of gas! Who would like a free ride?John________________________________________________________________________________
Pietenpol-List: Re: Don't know
Posted: Thu Apr 19, 2012 1:49 am
Original Posted By: "DaveG601XL"
Well, for what it's worth mine is here;
http://www.clifdawson.ca/Homepage4-10-0 ... pol.htmlIf that doesn't work;
http://www.clifdawson.ca/ClifA mile of road will take you a mile, but a mileof runway will take you anywhere> just looking for maybe a link for a bunch of piet pics in one place. or > maybe whoever reads this can include their Piet pic. thanks; Paul>>> Read this topic online here:>>
http://forums.matronics.com/viewtopic.p ... 164#371164>>> -----> No virus found in this message.> Checked by AVG -
www.avg.com> ________________________________________________________________________________Subject: Pietenpol-List: Re: Don't know
Posted: Thu Apr 19, 2012 6:27 am
I asked this same question to my FSDO Inspector a few years ago. He said to usethe paragraph in my flight limitations that deals with major changes as a guidelinefor returning to flight. He said it was not necessary to contact him,but recommended that you essentially place yourself back into "phase I" and flyoff 5 hours in your flight test area and afterwards write the same statementin the logbook that you wrote after your initial Phase I was complete "I certifythat the prescribed flight test hours have been completed and the aircraftis controllable throughout its normal range of.... yada yada yada." Straight from the horses mouth.--------David GallagherZodiac 601 XL-B: flying, 200+ hours nowNext project under construction: AircamperRead this topic online here:
Pietenpol-List: Re: piet pics
Posted: Sat Apr 28, 2012 6:25 pm
What is the diameter of your wheels, and tires if you don't mind me asking...?Looks wonderful assembled....!!--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: piet pics
Posted: Sat Apr 28, 2012 6:58 pm
thanks cliff; great work and very helpful pics. paulRead this topic online here:
Re: Pietenpol-List: Re: piet pics
Posted: Sat Apr 28, 2012 9:43 pm
Original Posted By: Rick Schreiber
You're welcome.Clif> >> thanks cliff; great work and very helpful pics. paul________________________________________________________________________________Date: Sun, 29 Apr 2012 09:30:27 -0500
RE: Pietenpol-List: fabric shrink temperature
Posted: Sun Apr 29, 2012 9:36 am
I went to 350 on mine. No problem as long as the structure is right.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Posted: Sun Apr 29, 2012 9:39 am
Rick,Glad to hear that you are at that stage...my favorite! I used 1.7 oz fabricand stopped at 300....call me chicken....Gary BootheNX308MB-----Original Message-----
Posted: Sun Apr 29, 2012 12:10 pm
Posted: Sun Apr 29, 2012 12:14 pm
