Pietenpol-List: What wood are some of you using?
Posted: Fri Nov 15, 2002 11:26 pm
Original Posted By: clif
Subject: Pietenpol-List: What wood are some of you using?I just wanted to see what some people are using?Any ideas or comments welcome.I have thought about using poplar.Dan________________________________________________________________________________Date: Fri, 15 Nov 2002 23:20:52 -0800
<< Pietenpol-List: What wood are some of you using?
Posted: Sat Nov 16, 2002 8:32 pm
Subject: Pietenpol-List: Re: Pietenpol-List Digest: 16 Msgs - 11/15/02In a message dated 11/15/02 11:54:38 PM, pietenpol-list-digest(at)matronics.com writes:>I started my Piet Feb. this year, and have completed the tail feathers and almost finished the Fuse. Another week or two and will weigh this and post the results on the Web. I'm using good Douglas Fir, VG, Kiln Dried and have learned to like it. Fir (good Fir) is readily available at your local lumberyard. You need to be able to pick your pieces. I'm using Basswood Plywood throughout, because I've tested the joints and find the glue bonds better than Birch/Fir. Maybe Birch/Spruce would be better?My local hardwood store sells nice Basswood lumber, and I would certainly buy some of this for non-satructural applications if I were to do the job over again.________________________________________________________________________________
