Pietenpol-List: cabin heat works great!
Posted: Wed Nov 20, 2002 4:40 pm
Original Posted By: "Brants"
So glad I put in cabin heat! It was a beeeeuuutiful afternoon up here in NJ. Into my second hour in the air, and just starting to relax a little with the feelof the Piet. Doing a big oval just west of the field over fields ( yes wehave fields in NJ) when I remembered my cabin heat. Worked great. Didn't exactlyburn my feet, but you could feel it. Now just have to cover the front holeand I'll be as snug as a bug.To anyone in the building stage that wonders should he or shouldn't he, I thinkit's worth it. Just for the book, I built four separate pipes for an A-65 withthe heat muffs by Tony Bengalis, of the same sized pipe split longways, spreadopen and attached to only one exhaust pipe, and capped at the rear, witha side discharge pipe for the scat hose. didn't think the heat would be there,but seems to be fine. One side feeds cabin heat , the other feeds carb heat.AIN'T LIFE GRAND!!!Read many times about when you fly it, it will all be worth while,,,well doublethat, and it goes for me.waltNX140DL(north N.J.)________________________________________________________________________________Date: Wed, 20 Nov 2002 20:15:17 -0600
Re: Pietenpol-List: covering the front hole
Posted: Wed Nov 20, 2002 10:53 pm
Re: Pietenpol-List: cabin heat, was: covering the front hole
Posted: Wed Nov 20, 2002 11:29 pm
Original Posted By: clif
Re: Pietenpol-List: cabin heat works great!
Posted: Thu Nov 21, 2002 9:27 pm
WaltWhat did you use for a controll valve for the cabin heat and can youcontroll it in flight?Dick Navratil----- Original Message -----
Posted: Thu Nov 21, 2002 11:50 pm
Original Posted By: Walter Allen
Posted: Fri Nov 22, 2002 3:41 pm
Dick,I used a regular push/pull wire control from AS&S ( can get you the part #if needed) and built a heat box from the Tony Bengalis book.walt----- Original Message -----
Posted: Fri Nov 22, 2002 5:37 pm
Original Posted By: chris gomez
