Pietenpol-List: 65HP climb rate
Posted: Sat Dec 07, 2002 10:34 am
John writes:>we would predict a rate of climb of 1056 fpm!>Yet he gets only max rate of climb of 700 fpm and sometimes less>This might indicate that his horsepower ratings are somewhat>optimistic.Well, I didn't want to over-inflate the claims that William makes, but they are there for the world to see on his website at http://www.flycorvair.com. Based on the actual, measured static RPM and actual, measured thrust that William's plane was getting, it developed more like 110 HP. The point was, as Mike Cuy explained, you need to know your plane's limitations based on what engine you have bolted to the firewall because there are things you just can't do with 65 or less horsepower up there. I will also point out that the climb rates that William stated were with passengers, in the busy traffic pattern at SNF. You really don't want to be climbing out at best climb in traffic or with passengers if there aren't any obstacles to clear, due to reduced visibility over the nose and speeds nearer to stall. Given that the plane was not being operated at best climb, the stated climbs were pretty good. William quoted some climb numbers higher than this to me but I didn't use them in my post because the point was made without them.To the rest of the folks on this list, be aware that John is running a turbocharged Subaru with a redrive, so his Piet will have truly stellar climb performance and if I were him I would challenge that Warner-powered Piet to a climb contest! And if I may again state my innermost feelings about the quintessential Piet image, it is of a plane that has a radiator out in front and an inline Ford 4-cylinder driving the prop!Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
