Pietenpol-List: Adjustable Trim
Posted: Sun Dec 08, 2002 7:34 pm
Has anyone installed adjustable trim on their Piet or GN1? If so, was it fromplans, or, parden the pun, did you just wing it? looking for any details beforeI get going on my elevators.Ken________________________________________________________________________________
RE: Pietenpol-List: Adjustable Trim
Posted: Sun Dec 08, 2002 7:57 pm
HI Ken,I installed a spring type system similar to the one Mike Cuy designed. Ihaven't flown yet so can't say how it works, but Mike uses his and has goodresults with it. It consists of a pair of springs that pull on the elevatorbellcrank. Moving a lever changes the tension on the springs, thus changingthe loading on the stick.Jack -----Original Message-----
Re: Pietenpol-List: Adjustable Trim
Posted: Sun Dec 08, 2002 8:02 pm
Original Posted By: "Ken & Lisa Rickards"
I plan on using a less conventional trim system... not an external tab butinternal "stick force reducer" using bungee and high power electric servo.I saw a drawing of one at some point cant find it now.DJ----- Original Message -----
Posted: Sun Dec 08, 2002 8:25 pm
Subject: Re: Pietenpol-List: Adjustable TrimPieters,Several days ago Tom Travis was over here in Shreveport from Dallas and we were looking over my Piet at Lucien Field. We were casually dicussing a few little changes I made, not severe. I pointed out to Tom that if I had any part to do over again I would try to come up with a ground adjustable horizontal stabilizer. It could be easily achieved by making the fuse side rudder hinge adjustable (lower one). That way you could avoid the bending of the stab as we were required to do. Just a thought but strong enough that I thought it needed mentioning.Corky still in La________________________________________________________________________________
Posted: Sun Dec 08, 2002 10:43 pm
Ken Rickards asked:> Has anyone installed adjustable trim on their Piet or GN1? If so, was itfrom plans, or, parden the pun, did you just wing it? looking for anydetails before I get going on my elevators.I can't swear to this, but have a vague memory of once seeing a Piet with asmall accessory vane on each side of the fuselage, under the horizontalstab, like they used on the early T-craft. Could be just something Ithought of doing myself--I've been pondering a Piet for a long time!--but itought to work.Owen Davies________________________________________________________________________________Date: Sun, 8 Dec 2002 20:45:58 -0800 (PST)
Posted: Mon Dec 09, 2002 7:43 am
Original Posted By: Jack Phillips [mailto:jackphillips(at)earthlink.net]
Thanks Jack, I have Mike Cuy's Video but haven't looked at it for a while.Where did you get the plans for this design. Ken.-----Original Message-----
Posted: Mon Dec 09, 2002 8:51 am
