Pietenpol-List: Press. oiled A
Posted: Sun Feb 02, 2003 11:25 pm
Original Posted By: ZigoDan(at)aol.com
Subject: Pietenpol-List: Press. oiled ALes: When you drill and pressure oiled the crank, did you stay with thebabbit, or go with insert bearings? Leon S Hutchinson Ks.________________________________________________________________________________
Re: Pietenpol-List: Press. oiled A
Posted: Sun Feb 02, 2003 11:42 pm
Subject: Re: Pietenpol-List: Press. oiled AI assume you guys are going to turn up the heat in your A powered ships. The pressured oil supply is not needed if turning Pietenpols recommended RPM. But I understand that it is nice to have. The engine is able to produce more power than designed for. Better breathing is what I have understood to help the most, increase the intake CFMS. The insert bearings I have seen available use a center thrust, is this the norm? If so it would not seem to be a good idea, since the thrust loads need to stay were they are for aircraft use. P.S. I have an A engine with most machine work done, and new bearings for $550.00 anyone interested email me at zigodan(at)aol.com.Dan ________________________________________________________________________________
RE: Pietenpol-List: Press. oiled A
Posted: Sun Feb 02, 2003 11:55 pm
Dan,I might be interested. Can you send me pictures.Chris-----Original Message-----
Posted: Mon Feb 03, 2003 9:27 am
