Pietenpol-List: Wing tanks
Does anyone have a sketch on how to build wing tanks for the piet?, or where canI find the information?Barry Davis________________________________________________________________________________Date: Thu, 06 Feb 2003 10:31:20 -0600
Re: Pietenpol-List: Airfoil
ahhhh yes.... I forgot abou that...the early GN-1's did use a host of J-3 partsincluding wings... but, the plans (since the early 70's) show the Piet airfoil...DJ----- Original Message -----
Re: Pietenpol-List: Wing tanks
Original Posted By: "DJ Vegh"
Subject: Re: Pietenpol-List: Wing tanksBarry: It's not exactly a sketch, but try: http://www.geocities.com/keriannprice/K ... __________
Original Posted By: "Doc Mosher"
Sorry Doc, Cub's use a USA 35B airfoil not a Clark YCy Galley - Bellanca Champion ClubNewsletter Editor & EAA TCwww.bellanca-championclub.comWe support Aeroncas----- Original Message -----
Subject: Re: Pietenpol-List: AirfoilExperts,Granted that for several reasons the Piet has very little float after flair. Question: Would this airfoil of the Cub perhaps extend the float of a Piet somewhat. It WAS designed several years after the Piet and maybe, just maybe, some progress could be identified. Just wondering without using my can opener again. An old southern boy just whittlin and dreamin________________________________________________________________________________
Barry,, The Tony Bingelis "Sport plane construction techniques"book, it'sthe yellow one, has some great examples of fiberglass tanks. Plus a lot ofother good things in there as well. I used his technique, measured thecenter section and went from there. If you go with the center wing tank,remember to take the bolt heads into concideration when measuring.Carl----- Original Message -----
Re: Pietenpol-List: F*CK Y*U!!!!!!!!!!!!!HAIL VIKTORY!!!!!!!!!!!!
Subject: Re: Pietenpol-List: F*CK Y*U!!!!!!!!!!!!!HAIL VIKTORY!!!!!!!!!!!!Thanks Matt,We really ought to try and identify the SOB and take him for a ride.CMC________________________________________________________________________________
Original Posted By: "Kip & Beth Gardner"
Thanks Barry----- Original Message -----
Could you spare another copy of those plans. Let me know the cost and I willsend it to you.Address is Doyle CombsP. O. Box 421Lometa, Texas 76853thanks very much----- Original Message -----
ThanksBarry Davis728-B Bankhead AveCarrollton, Ga.30117----- Original Message -----
