Pietenpol-List: Aileron Gap Seal
Posted: Fri Apr 25, 2003 12:25 pm
Original Posted By: "DJ Vegh"
The aileron design on the GN1 is somewhat different that of the Piet. Thisdesign has about a 1" gap between the aileron support spar and the aileron.D.J. has come up with an ingenious method of filling this gap, but I waslooking for something a little easier to build. The Piet design allows the use of a piano hinge, thus negating the need fora gap seal. Question? Has any GN1 builder modified the aileron design tomimic that of the Piet design. If so, how easy was it to do? Seems to methat the Piet design is just as easy to build and you would not have toworry about sealing the gap! Ken GN1 2992________________________________________________________________________________
