Pietenpol-List: Drag/Anti-Drag
Posted: Tue Apr 29, 2003 9:31 am
Original Posted By: "Craigo"
Does everyone go with the turnbuckles and cables, or are there other ways to makethese wires? It just about kills me to order $3000 worth of turnbuckles forall six Piets. There's got to be a better way.Does anyone have info on spoke nipples and solid wire? My Jr.Ace has solid wireswith cut threads (I am not builder of this plane).One of our builders has a PA22 and it has smooth wires and compression fittingson wing and tail feather flying wires. These fittings just squeeze the smoothwires.Barry________________________________________________________________________________
Re: Pietenpol-List: Drag/Anti-Drag
Posted: Tue Apr 29, 2003 9:49 am
Original Posted By: cat_designs(at)juno.com
> > > > Does everyone go with the turnbuckles and cables, or> are there other ways to make these wires? It justabout> kills me to order $3000 worth of turnbuckles for all> six Piets. There's got to be a better way.Barry - it is possible to go with solid wires andleft/right threads. I used AN665-21R and L terminalends on 3/16 ss wire, with lock nuts. You woild haveto get a LH die . . . . Best of luck!CraigLake Worth, FLBakeng Duce NX96CWPeoplePC: It's for people. And it's just smart.
http://www.peoplepc.com ________________________________________________________________________________Date: Tue, 29 Apr 2003 14:53:31 GMTSubject: Re: Pietenpol-List: Drag/Anti-Drag
Posted: Tue Apr 29, 2003 10:13 am
Posted: Tue Apr 29, 2003 10:18 am
The GN-1 calls for solid wire for drag/anti drag. I'll be doing mine withthat method. The ends of the wires are threaded and have forks. I believethe Aeronca Champ is the same way.DJ VeghN74DVwww.raptoronline.comMesa, AZ----- Original Message -----
Posted: Tue Apr 29, 2003 10:44 am
Original Posted By: "Les Schubert"
It might be interesting to note that the MacWhyte S.S. flying wires all hadcut threads per PMA.----- Original Message -----
Posted: Tue Apr 29, 2003 6:26 pm
You COULD go to Home Depot and get the $1.50 ones that Fisherman told usabout...TedLaughing and ducking and running----- Original Message -----
Posted: Tue Apr 29, 2003 7:22 pm
Posted: Tue Apr 29, 2003 7:48 pm
Subject: Re: Pietenpol-List: Drag/Anti-DragTed,Mine work fine. I took the F man's suggestion.YKW YKW________________________________________________________________________________
RE: Pietenpol-List: Drag/Anti-Drag
Posted: Wed Apr 30, 2003 6:43 pm
The Christavia, a Canadian design, uses solid wires with threaded ends andinstead of forks uses motorcycle spoke nipples.The nipples pass through the spar on the neutral axis and bear againstwashers on angled blocks.John-----Original Message-----
Posted: Thu May 01, 2003 7:02 pm
John,This is how my AP suggested I do the wings to get around the turnbuckles.But I opted to go with original design.walt13 1/2 down out of 25----- Original Message -----
