Pietenpol-List: Drag-anti drag wires.
Posted: Thu May 01, 2003 8:04 am
Original Posted By: "rambog(at)erols.com"
Subject: Pietenpol-List: Drag-anti drag wires.The modernized Corbin Aces redrawn by Poberzney use hardware store eyebolts with the loop welded shut, mounted as described by John Mcnarry,then cables are used instead of rod. Eye bolt ends are double nutted,lock nut over a regular nut used as a jam nut. Leon S.________________________________________________________________________________
