Pietenpol-List: Re: torque tube question
Posted: Wed May 07, 2003 6:20 pm
I have seen a number of people talk about putting a shim under the forwardtorque tube bearing to raise it up off the floor. I always assumed thatthis was because the torque tube touched something, most likely where itpasses through the back of the front seat between the "V" formed by thesquare spruce diagonal braces. Is this correct?My torque tube sits flat on the floor at both the front and back endswithout a shim. It did touch slightly at the front seat back, but a lighttouch with a small sanding drum gave it clearance. My problem is that withthe interconnect between the front and rear control sticks, the interconnecthits the "V" brace on the side that it is on with what appears to be a verysmall aileron deflection.Have some of you had this problem? I am wondering whether the shim underthe front bearing may have been to raise the torque tube up so that theinterconnect hits the diagonal later, or maybe some of you have "jogged" theinterconnect so that it does not hit, or maybe whether the aileron travel Ihave is sufficient and I am worrying about nothing.Sound familiar to anyone??Gene________________________________________________________________________________Date: Wed, 7 May 2003 19:35:29 -0400
