Pietenpol-List: fuel system
Posted: Mon May 19, 2003 8:19 pm
Hey AllNow that the warmer weather is coming to Mn. I can work with the hangar door open.I get a constant stream of visitors stopping by to chew the fat. It's anotherside benefit of having a Piet.Anyway, today a A&P stopped by and made a couple of comments I thought worth passingon. He commented first on my placement of the gascolator on the firewall.He suggested that I move it so that at rest it was lower that the carb bowlat rest, to be the lowest point in the system. Also, he suggested to do a fuelflow test to verify that at rest, the fuel line provides a flow of 10 gal/hr.with minimum usable fuel remaining in the tank to simulate adequate flow fora go around. Also an extended test of the flow to verify adequate ventingof the tank.Just a couple of points I don't recall having seen on the list.Dick ________________________________________________________________________________
