Pietenpol-List: Re: Question #7
Posted: Sun Jun 01, 2003 9:03 pm
To add to my list of questions (not that my previous ones have generatedmany responses):7. Are any of you offsetting the vertical fin to the left, or are youaligning it with the fuselage?????Gene________________________________________________________________________________
RE: Pietenpol-List: Re: Question #7
Posted: Sun Jun 01, 2003 9:13 pm
Gene,I drilled two sets of holes so that if I find I need more offset (the firstset is on the centerline) I can do it easily. I'm expecting to not need thesecond set of holes, though. I think most Piets flying have the fincentered on the centerline.Jack -----Original Message-----
Re: Pietenpol-List: Re: Question #7
Posted: Sun Jun 01, 2003 11:44 pm
Subject: Re: Pietenpol-List: Re: Question #7In a message dated 6/1/03 9:03:31 PM Central Daylight Time, rambog(at)erols.com writes:>Gene,My fin is aligned with the fuselage, but I ofset the A65 engine mount about 1/16" to the right. Low power aircraft usually don't need the fin offset to account for torque.Chuck________________________________________________________________________________
Posted: Mon Jun 02, 2003 6:39 am
I don't know about low powered airplanes not needing the offset, have youever seen a Aeronca Champ fuselage? The fin is offset nearly an inch. ACub is offset, too. I don't know for sure about the common belief that theoffset is for torque, I believe that it is to correct for adverse yaw as aresult of P factor. I know the Cessna Airmaster I used to have had thenon-adjustable fin set in the middle, and the thing would never fly handsoff without rolling off to one side until I discovered that they originallycame with an externally adjustable rudder trim tab (which the previousrestorer had omitted for appearance sake). Once I installed the tab, itflew perfectly.I do NOT want to install a tab on the Piet if I can help it. C'mon you guyswith flying airplanes, especially Model A powered, offset fin or not?????Gene----- Original Message -----
Posted: Mon Jun 02, 2003 7:47 am
Posted: Mon Jun 02, 2003 10:36 am
Original Posted By: Jim Sury
Posted: Mon Jun 02, 2003 12:00 pm
Posted: Mon Jun 02, 2003 12:11 pm
Posted: Mon Jun 02, 2003 1:54 pm
I built it right down the middle, with the engine mount per plans ( only alittle longer) and yaw is not a problem.walt----- Original Message -----
Posted: Mon Jun 02, 2003 2:16 pm
Posted: Mon Jun 02, 2003 4:45 pm
