Subject: Pietenpol-List: Off set vert. finGene: I was going to off set the fin, but decided to set it straightwith the fus. center line. I beefed up a small area of the ruddertrailing edge and drilled it so I can add a trim tab later if I need to.I also did the same to the elevator trailing edges after the longdiscussion about trim problems that ran on the list some months ago.Leon S.________________________________________________________________________________
