Pietenpol-List: C-85 temperature bulb adapter
Posted: Mon Jun 09, 2003 10:25 am
Re: Pietenpol-List: C-85 temperature bulb adapter
Posted: Tue Jun 10, 2003 10:41 am
BillI went thru this a while back. I'm not sure which one the C-85 uses and Ihad to order and return a couple of times. Try Wag Aero catalog p/nA-007100 or A-007200 pg 13 . I have a A-65 so it may not be the same one.Dick----- Original Message -----
Re: Pietenpol-List: Minimum Bend Radiuses
Posted: Tue Jun 10, 2003 10:57 am
Air Craft Spruce says 3 times the thickness.Cy Galley, TC - Chair, Emergency Aircraft Repair, OshkoshEditor, EAA Safety Programscgalley(at)qcbc.org or experimenter(at)eaa.orgAlways looking for articles for the Experimenter----- Original Message -----
RE: Pietenpol-List: Minimum Bend Radiuses
Posted: Tue Jun 10, 2003 11:27 am
Posted: Tue Jun 10, 2003 1:36 pm
Original Posted By: cat_designs(at)juno.com
Subject: RE: Pietenpol-List: Minimum Bend Radiuses
Re: Pietenpol-List: save your back--leave the firewall for last
Posted: Tue Jun 10, 2003 2:19 pm
I kind of did the same thing, but when I finally put it in I cut a hole(about 6" dia or big enough to fit a hand thru) in both the firewall ply inthe center of the lower section below the ash crossmember. And also oneunder the fwd tank ply. Made it accessable right up to the steel firewallinstallation.walt----- Original Message -----
