Pietenpol-List: Blakesburg
Posted: Wed Aug 27, 2003 5:16 pm
Original Posted By: "Dick and Marge Gillespie"
Any Pietors going to Blakesburg this weekend?Jack Textor________________________________________________________________________________
Re: Pietenpol-List: Blakesburg
Posted: Wed Aug 27, 2003 5:51 pm
Original Posted By: "Jack Textor"
Where's that?walt evansNX140DL----- Original Message -----
Posted: Wed Aug 27, 2003 6:59 pm
Posted: Wed Aug 27, 2003 7:22 pm
Posted: Wed Aug 27, 2003 10:22 pm
Original Posted By: "Al Latham"
Subject: Re: Pietenpol-List: BlakesburgIn a message dated 8/27/03 5:23:37 PM Central Daylight Time, jack(at)personnelincorporated.com writes:>I'm planning on flying my Piet up to Blakesburg Iowa, this weekend. Leave Friday - late afternoon, after work, overnight somewhere enroute, arrive at Antique Field sometime Saturday morning. Problem is, there is a big front movingin on Friday, with LOTS of rain in it. Could put a damper on the weekend.Chuck G.________________________________________________________________________________
Posted: Wed Aug 27, 2003 10:40 pm
Original Posted By: "Kip & Beth Gardner"
Hi Kip,I got off the phone with Karen a bit ago and Gene is stuck in WV for now. Heis in the TravelAir.I hope to get there early Friday morning, but if Gene dosen't make it I mayscrub the whole thing.Al LathamLathrop, MO.----- Original Message -----
RE: Pietenpol-List: Blakesburg
Posted: Thu Aug 28, 2003 7:55 am
Walt,It is at Antique Airfield, Blakesburg, IA which is just west of Ottumwa, IA.The ID is IA27. Sponsored by the Antique Airplane Association. It is amember only event. You can learn more at their site
http://www.aaa-apm.org. Very casual and many nice antiques.Jack Textor -----Original Message-----
Posted: Thu Aug 28, 2003 8:16 am
Posted: Sat Aug 11, 2012 6:04 pm
Original Posted By: JOSEPH SWITHIN
Posted: Sat Aug 11, 2012 10:03 pm
I'm planning on making Blakesburg. Not sure what days. (not in my Piet, of course)GeneOn Aug 11, 2012, at 6:59 PM, JOSEPH SWITHIN wrote:> Dick,> I will get to Blakesburg on Thursday around noon. I will leave Saturday afternoon. > > Joe> Morris, IL> hunting and gathering> > > ============================================================================================================================================> ________________________________________________________________________________
Pietenpol-List: Re: Blakesburg
Posted: Sun Aug 12, 2012 3:26 pm
Original Posted By: "K5YAC"
I applied two coats of Helmsman's spar varnish on my wings, tail surfaces and everythingthat would be covered. It is supposed to be good stuff. On areas thatwill be exposed or visible, I am using System 3's marine grade varnish...it is supposed to have superior UV protectors and it goes on clear (not yellowish),so the wood really looks beautiful. The other major difference... Helmsman's = $15 at Home Depot or other home improvement stores.System 3 = $40 at Woodcraft or other wood working or marine stores. Mileage may vary... this is just what I've found.--------Mark ChouinardWings, Center Section and Empannage and Fuse framed up - Working on Landing GearRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Blakesburg
Posted: Sun Aug 12, 2012 3:29 pm
Original Posted By: V Groah
I'm considering going... it all depends on work. I'll let y'all know as time getscloser if I plan to be there. Tyler and I stopped in on our way up to Brodhead...we would love to see the place in full swing.--------Mark ChouinardWings, Center Section and Empannage and Fuse framed up - Working on Landing GearRead this topic online here:
Posted: Sun Aug 12, 2012 10:44 pm
Are you arriving via car, attempting a short-field landing in your big jet airliner, or bringing the Travel Air?Ryan Muellerrmueller23(at)gmail.comOn Aug 11, 2012, at 10:03 PM, Gene Rambo wrote:> I'm planning on making Blakesburg. Not sure what days. (not in my Piet, of course)> > Gene> > On Aug 11, 2012, at 6:59 PM, JOSEPH SWITHIN wrote:> >> Dick,>> I will get to Blakesburg on Thursday around noon. I will leave Saturday afternoon. >> >> Joe>> Morris, IL>> hunting and gathering>> >> >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> ________________________________________________________________________________
Posted: Mon Aug 13, 2012 12:56 pm
Paul,I used Poly Fiber throughout. I stuck to what the manual said. We had used Stittsduring the original build and it held up great so I decided to use what proveddurable to me. The Spar varnish and Chromate primer were the weak pointsover the years. But in 1971 that is all that was available. It has been 11 years since the rebuild now and still looks almost new. I wouldchoose to do it the same way again.BTW, Stitts and Poly Fiber are the same product.Your results may vary,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Blakesburg
Posted: Mon Aug 13, 2012 5:36 pm
Original Posted By: Dan Yocum
Airline to somewhere and rent a car. On Aug 12, 2012, at 11:44 PM, Ryan Mueller wrote:> Are you arriving via car, attempting a short-field landing in your big jet airliner, or bringing the Travel Air?> > Ryan Mueller> rmueller23(at)gmail.com> > > > > On Aug 11, 2012, at 10:03 PM, Gene Rambo wrote:> >> I'm planning on making Blakesburg. Not sure what days. (not in my Piet, of course)>> >> Gene>> >> On Aug 11, 2012, at 6:59 PM, JOSEPH SWITHIN wrote:>> >>> Dick,>>> I will get to Blakesburg on Thursday around noon. I will leave Saturday afternoon. >>> >>> Joe>>> Morris, IL>>> hunting and gathering>>> >>> >>> >>> >> >> >> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>> href="x-msg://694/3D%22http://
www.matronics.com/Navigator?Pietenpol-L ... enpol-List>> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>> href="x-msg://694/3D%22http://forums.matronics.com%22">
http://forums.matronics.com>> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>> href="x-msg://694/3D%22http://
www.matronics.com/contribution%22">http ... ntribution>> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>> > > > ============================================================================================================================================> ________________________________________________________________________________Date: Mon, 13 Aug 2012 20:44:12 -0500
Re: Pietenpol-List: A65 pushrod housing connectors
Posted: Mon Aug 13, 2012 9:15 pm
Original Posted By: "Dan Yocum"
Is this what you're looking for?
http://www.realgaskets.com/files/colorpush.htmGreg Cardinal----- Original Message -----
Pietenpol-List: Re: Look this blade
Posted: Mon Aug 13, 2012 9:29 pm
Yes, I've seen one before! THAT one! (You told me about it several years ago);o) ;o)--------Oscar ZunigaMedford/Ashland, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 13 Aug 2012 21:31:31 -0500
Posted: Tue Aug 14, 2012 1:28 am
And no more fighting those stupid hog ring clamps too=85.Ryan Muellerrmueller23(at)gmail.comOn Aug 13, 2012, at 9:31 PM, Dan Yocum wrote:> > That could be it - I never saw a picture, only read the words on a page.> > Thanks, Greg!> > Dan> > > On 08/13/2012 09:15 PM, Greg Cardinal wrote:>> >> >> Is this what you're looking for?>> >>
http://www.realgaskets.com/files/colorpush.htm>> >> Greg Cardinal>> > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Look this blade
Posted: Mon Aug 20, 2012 8:51 pm
Original Posted By: "ldmill"
I dropped of a sheet of 4130 x .032 to a friend of mine who owns a steel fabricationshop, and he asked if I could use another kind of steel than 4130. He askedbecause he said he had plentiful amounts of 1010 sheet steel in varying quantities,and he said if I wanted to compensate for the strength differences,he thought I could cut the rest out of stock he has on hand if I wanted.As metal is my weakness here (in experience level), I am wondering what you folksthink about this, outside of my knee-jerk reaction to say "No" just becauseit's not sold at ACS or Wicks... My bird will have extra wing area, and yet weight is still important, but whatother points might I need to consider if I looked at using another steel asidefrom 4130? Didn't the 1930's Piets use 1025 or something? Thanks for your perspectives. I searched the archives before posting to see ifthis had been asked and didn't see anything, but I might have missed it.MarkRead this topic online here:
