Original Posted By: "DJ Vegh"
Is there anywhere where one can buy Sitka spruce locally, around Philadelphia orAllentown PA? I don't want to pay the shipping that they want to charge atAS&S. I would consider using Douglas fir but am unsure as to what the requirementswould be to qualify as safe to use in my wings ribs. So if someone has anypointers on what would make fir good enough to use in aircraft that I woulduse that rather than paying shipping.________________________________________________________________________________
Pietenpol-List: local spruce
Re: Pietenpol-List: Grega ailerons
Original Posted By: "dan john"
grega ailerons do require sealing. Most do it by using a strip of fabric.I'm planning on using a different method. my version can be seen here:http://www.imagedv.com/aircamper/log/im ... eron.htmIf I were to do it over again I would have rather used pieano hinge like aPiet. Too late for me now as I have already made all my ribs.DJ VeghN74DVMesa, AZwww.imagedv.com/aircamper----- Original Message -----
Re: Pietenpol-List: local spruce
Is any one aware of a PGN, which is a cross between a Piet and a GN-1? Theywere designed in Ohio. ThanksDoyle Combs________________________________________________________________________________Date: Sun, 14 Sep 2003 20:34:36 -0700 (PDT)
09/15/2003 08:11:04 AMI agree check for local boat shops they should be able to help you locate asource. Many years ago when I lived outside Philly there were a number ofbuilders in Deleware.Best wishesJohn________________________________________________________________________________
