Original Posted By: "Gadd, Skip"
> > >> > > >> > >Hey Ed,> > >> > >What is the actual weight of your tail wheel? ACS> says it should weigh 5.2> > >pounds which is heavier then the Matco at 5> pounds. I would think the > > >Heath> > >would be lighter.> > >> > >Chris T.> > >Sacramento, Ca> > >> > >> > >Quoting Ed Grentzer :> > >> Grentzer" > > >> > > >> > > >> > > > Sounds like we're pretty close DJ...I> weighed my Piet ( not GN-1) > > >last> > > > week. it's just like yours but with pilot's> seat belt and harness, aux. > > >wing> > > >> > > > tank, all instruments, trim system and motor> mount but no rudder pedals > > >or> > > > fire wall mine came in at 212#. Mine has a> Heath tailwheel and Goodyear > > >6"> > > > wheels and brakes the motor mount is a bed> mount for my Franklin ( a > > >little> > > > heavier than a Continental mount). Ed G.> > > >> > > >> > > > >From: "DJ Vegh" > > > > >Reply-To: pietenpol-list(at)matronics.com> > > > >To: > > > > >Subject: Re: Pietenpol-List: Fuselage Weight> > > > >Date: Thu, 18 Sep 2003 09:43:03 -0700> > > > >> Vegh" > > > > >> > > > >My 90% complete fuselage (as shown in the> link below) weighs in at > > >195lb.> > > >> > > > >That includes controls and rudder pedals, J-3> landing gear, aluminum> > > > >cabanes, Grove wheels and brakes and Matco> tailwheel. No instruments,> > > > >fuel tank, seat belts, or control cables.> > > > >> > > > >here's the link that shows the plane in that> state of completion> > > > >> > > >>>
http://imagedv.com/aircamper/log/image- ... -19-03.htm> > > > >> > > > >I'm not sure if I'm on par with what it> should be or not.... can > > >someone> > > > >else chime in with some fuse numbers??> > > > >> > > > >DJ Vegh> > > > >N74DV> > > > >> > > > >> > > > >----- Original Message -----> > > > >From: Barry Davis> > > > >To: pietenpol-list(at)matronics.com> > > > >Subject: Pietenpol-List: Fuselage Weight> > > > >> > > > >> Davis" > > >> > > > >> > > > >Does anyone have the weight of a bare wood> fuselage?> > > > >Without fittings and landing gear or tail> feathers, just the framework > > >with> > > >> > > > >all the plywood and gussets installed, but> without seats.> > > > >> > > > >We have our second steel fuselage welded up> now and the question came > > >up> > > > >about weight. Our regular work night is> Monday and we plan to take > > >scales> > > > >and weigh up a 4130 steel fuselage. I'll post> the weight on Tuesday.> > > > >> > > > >Barry Davis> > > > >> > > > >> > > > >>This email has been scanned for known> viruses and made safe for > > >viewing by> > > >> > > > >Half Price Hosting, a leading email and web> hosting provider. For more> > > > >information on an anti-virus email solution,> visit> > > > >.> > > > >> > > > >> > > >> > > > Compare Cable, DSL or Satellite plans: As low> as $29.95.> > > >
https://broadband.msn.com> > > >> === message truncated ========Del-New Richmond, Wi"farmerdel(at)rocketmail.com"__________________________________http://sitebuilder.yahoo.com________________________________________________________________________________
