Pietenpol-List: shoulder harness
Posted: Tue Oct 07, 2003 7:36 pm
I want to put a shoulder harness in my piet. The crossmember behind thepilot is low and I've heard that there are fears of spinal compressioninjuries in case of impact... which kind of makes sense. I'm thinkingof reinforcing the turtle deck former behind the pilot and running theharness out of the very top of that and then running a cable back in thefuselage to some solid cluster or even to the tailskid/keel area. Passenger harness can obviously go to the cabanes so that's easy. Whathave you guys done or seen that works. My problem also is that Ipurchased a project and the fuselage is already covered but the guy madeno provisions for seat belts of any kind so I've got to go in andretrofit something.thoughts??Douwe Blumbergdouweblumberg(at)earthlink.net I want to put a shoulder harness in mypiet.The crossmember behind the pilot is low and I've heard that there arefears ofspinal compression injuries in case of impact... which kind of makessense. I'm thinking of reinforcing the turtle deck former behindthe pilotand running the harness out of the very top of that and then running acableback in the fuselage to some solid cluster or even to the tailskid/keelarea. Passenger harness can obviously go to the cabanes so that'seasy. What have you guys done or seen that works. My problemalso isthat I purchased a project and the fuselage is already covered but theguy madeno provisions for seat belts of any kind so I've got to go in andretrofitsomething.thoughts??Douwe Blumbergdouweblumberg(at)earthlink.net________________________________________________________________________________Date: Tue, 7 Oct 2003 19:33:29 -0700 (PDT)
