Pietenpol-List: Wooden split axle
Posted: Fri Oct 17, 2003 2:35 pm
Original Posted By: "Ken Chambers"
RE: Pietenpol-List: Wooden split axle
Posted: Fri Oct 17, 2003 5:08 pm
Original Posted By: Ken Chambers [mailto:kchambers(at)winternals.com]
I can certainly believe that you could make the Vees from wood--the loadswould be about the same as for the straight axle. The problem would be inthe moments involved in attaching the stub axles to a wooden Vee. With astraight axle, it's not a problem, there's no bending moment transfered tothe wood; everything is (almost) in compression. With the split axle, therewill be a whole lot of torque, one way or another, when a wheel startstaking load. It is approximately balanced by the extension for the shockabsorber strut, but will still be sensitive to bounces and side loads.Maybe a REALLY BIG gusset on the bottom of the Vee would work.Gene-----Original Message-----
Re: Pietenpol-List: Wooden split axle
Posted: Mon Oct 20, 2003 1:17 pm
Posted: Mon Oct 20, 2003 2:24 pm
The laminated tailspring sounds like fun! Let us know how it turns out. Iforgot--are you doing a skid or wheel? A steel shoe seems like it wouldwork fine for a skid--a wheel could have the same design challenges as themain gear.Gene-----Original Message-----
Posted: Tue Oct 21, 2003 1:01 pm
