Pietenpol-List: Rib Full Size Pattern ????
Posted: Sat Oct 25, 2003 3:56 pm
Re: Pietenpol-List: Rib Full Size Pattern ????
Posted: Sat Oct 25, 2003 6:10 pm
Posted: Sun Oct 26, 2003 8:30 pm
Lofting is the process where you draw the pattern to full size on the boardyou will use as the rib jig.Kent> >Date: Sat, 25 Oct 2003 21:32:05 -0400> >To: "Jack Textor" > >From: Jim Ash > >Subject: Re: Pietenpol-List: Rib Full Size Pattern ????> >> >I'll bite. What specifically do you mean by lofting?> >> >Jim Ash________________________________________________________________________________Date: Sun, 26 Oct 2003 22:38:13 -0800
Posted: Mon Oct 27, 2003 7:22 am
Posted: Mon Oct 27, 2003 12:05 pm
Cliff,Very interesting! Can you explain each?walt evansNX140DL----- Original Message -----
Re: Pietenpol-List: Re: PAL nuts
Posted: Mon Oct 27, 2003 7:35 pm
Original Posted By: "Craig Lawler"
A friend of mine had a cylinder on his C-85 loosen up in flight. By thetime he got on the ground the cylinder was mangled and so was the case. NOPAL Nuts.Go figure. You safety EVERYTHING on an airplane EXCEPT the bolts that holdthe engine together. Does this make any sense?When my buddy that trashed his engine has a visitor at his strip, he willpoke his head into the cowl to see if it has pal nuts. If the visitor doesnot, he gives the visitor a small bag with the requesite pal nuts to takewith him and install at his leisure.Use the Pal Nuts, despite what the experts say.... They are in the businessof selling engines...chris bobkaA&P IA----- Original Message -----
Posted: Tue Oct 28, 2003 9:13 am
Posted: Fri Apr 28, 2017 9:30 pm
Original Posted By: Jim Ash
>To: "Jack Textor" >From: Jim Ash >Subject: Re: Pietenpol-List: Rib Full Size Pattern ????>>I'll bite. What specifically do you mean by lofting?>>Jim Ash>>>While making my rib jig, I compaired the full size patteren with the>>dimentions given in the plan. I lofted the measurements to the pattern.>>They are off by 3/16th of an inch in places. It also seem like I have>>too much room above the front spar and top capstrip. Which should I>>beleive? When tanfering the dimentions to the jig, I have made sure the>>spars are 27 3/4" apart and parallel.>>Help! and Thanks!>>Jack Textor>>Des Moines>>Sender: owner-pietenpol-list-server(at)matronics.com>>Precedence: bulk>>Reply-To: pietenpol-list(at)matronics.com>>>>>>>>________________________________________________________________________________Date: Sun, 26 Oct 2003 18:27:14 -0500
