Pietenpol-List: cork floats
Posted: Wed Oct 29, 2003 1:03 pm
Shellac may be fine for coating cork that floats in avgas but do not use it for auto gas. I have a 1926 Disappearing Propellor Boat (from Canada) that uses a Kingston carb. Originally, the cork carb floats were coated with shellac which worked fine. Today's gas has many additives including some that dissolve the shellac. Then the float sinks and gas pours in through the needle and seat and overflows over the bowl and collects in the bilge. By this time the engine has stopped so you have to take apart your carb and put in a new cork float (if you have one). This all happens during a raging sea on Georgian Bay.The lesson is to coat your float with a thin layer of epoxy that is impervious to the additives (toxins) in today's auto gas. Never had a problem since.Jeff in beautiful clear warm TX where I've just cut out the ailerons from the wing.________________________________________________________________________________
Re: Pietenpol-List: cork floats
Posted: Wed Oct 29, 2003 6:07 pm
Subject: Re: Pietenpol-List: cork floatsIn a message dated 10/29/2003 1:18:52 PM Central Standard Time, jeff2dogs(at)hotmail.com writes:The lesson is to coat your float with a thin layer of epoxy that is impervious to the additives (toxins) in today's auto gas. Never had a problem since.I have had a bottle cork that I coated with t-88 floating in a jar with auto gas for over six months. Look at it periodically and have found no deterioration to date. And the cork is still showing the same displacement. Forwhat it's worth Don Hicks ________________________________________________________________________________
Posted: Wed Oct 29, 2003 8:24 pm
Subject: Re: Pietenpol-List: cork floatsIn a message dated 10/29/03 1:18:53 PM Central Standard Time, jeff2dogs(at)hotmail.com writes:>I used Polyester Resin to coat the cork...the auto body stuff. It's the same material I used to build my two fuel tanks with. This will also serve to find out if something in the fuel, like alcohol, has deteriated the resin the tank is made from. Yesterday, I was taking off from a local grass strip, and didn't realize how high one of the whooptie doo's were. I had 15 gal of fuel onboard, and ontake off run, the tail came up, airspeed was just passing 30 mph, and Ba-Wump !! It was like a ramp that tossed 'er in the air before she was ready to fly !! I managed to hold 'er off in ground effect, and flew out of it. Surprise take-off for sure, but she took care of me!!Chuck G.________________________________________________________________________________
Posted: Wed Oct 29, 2003 8:53 pm
I can hardly wait for someone to ask what a "whooptie doo" is........---- Original Message -----
Posted: Wed Oct 29, 2003 11:02 pm
Subject: Re: Pietenpol-List: cork floatsIn a message dated 10/29/03 8:56:05 PM Central Standard Time, jim_markle(at)mindspring.com writes:>Jim,The context I used the 'whoopie doo' term, was in describing the uneven surface of the grass runway. No doubt, it was derived from a nautical term meaning'Sailing across the white tops'. :)Chuck G.________________________________________________________________________________Date: Wed, 29 Oct 2003 21:49:23 -0800 (PST)
RE: Pietenpol-List: smoldering over Lake Erie
Posted: Thu Oct 30, 2003 1:11 am
Posted: Fri Oct 31, 2003 7:06 am
Original Posted By: "Alex Sloan"
Can anybody tell me what happens if a cork sits in auto gas and isn't sealed withsomething? I'm tryint to figure out what would happen. Does it get sink eventuallyor come apart?DouweDouweblumberg(at)earthlink.net________________________________________________________________________________
