Original Posted By: Gnwac(at)cs.com
Pietenpol-List: Wingspan
Re: Pietenpol-List: Wingspan
Original Posted By: "Mike B."
Subject: Re: Pietenpol-List: WingspanIn a message dated 12/6/03 2:16:32 PM Eastern Standard Time, piet(at)pointdx.com writes:> Does anyone have any experience/knowledge about building Piets with varying> wingspans? Seems to me that if one isn't going for speed, one may as well go > for> shorter takeoff rolls(?), shallower glide path(?), etc, and therefore maybe> extend the wings just a bit.> > Would this require any changes to the tail surfaces?> > -Mike B.I have and idea you might try.If you have access to an RC Flight Simulator, like RealFlight G2, one you can make changes to the aircraft with, you could do just that. Lengthen the wings, change the cord, reposition the tail surfaces, as well as enlarge or change the shape of the tail surfaces. Then you can fly these changes to see howthey fly. I think FMS is another Simulator, one that already has a Pietenpol data file for it. The structural changes you'd have to take on yourself however. Changing one thing at a time would be the best thing to do.________________________________________________________________________________Date: Sat, 06 Dec 2003 20:22:59 -0500
Subject: Re: Pietenpol-List: WingspanIn a message dated 12/6/03 1:16:32 PM Central Standard Time, piet(at)pointdx.com writes:>Mike,Anytime you change anything on an airplane, it has a ripple effect. ESPECIALLY, something like the wing !! The required engineering involved wouldbe in depth. The Pietenpol is a well proven design, and if you change the wingspan,you change stress points, the size of the empenage, trim drag, inertia effects, component size, bending moments, and a host of other things. Don't changethe wing !! Build it to the proven plans. You will live much longer !!Chuck GantzerWichita KSNX770CGPietenpols Forever !!________________________________________________________________________________
Original Posted By: rhartwig11(at)juno.com
Subject: Pietenpol-List: Wingspan
You can find an article about Mark Anderson's Pietenpol here,http://members.aol.com/bpabpa7315/mark.html. It says his wing are 2 feetlonger.Chris T.Sacramento, CA----- Original Message -----
Original Posted By: Dmott9(at)aol.com
There's someone over on the west coast of Florida who stretched the wings onhis Piet. Can't remember his name and I can't find my notes right now but Isat in his plane at SNF 2003. It was stretched 4 feet (not sure if that wastotal, or per side) and the plane has been modified to look a bit like aCurtiss Jenny. Said it flew just like a Pietenpol... not sure the reason forthe change though.-Mike> wingspans? Seems to me that if one isn't going for speed, one may as wellgo> for> shorter takeoff rolls(?), shallower glide path(?), etc, and thereforemaybe> extend the wings just a bit.Mike Whaley merlin@ov-10bronco.netWebmaster, OV-10 Bronco Associationhttp://www.ov-10bronco.net/http://www.ov-10bro ... __________
Subject: Re: Pietenpol-List: WingspanIn a message dated 12/7/03 5:26:10 PM Eastern Standard Time, catdesign(at)intergate.com writes:> You can find an article about Mark Anderson's Pietenpol here,> http://members.aol.com/bpabpa7315/mark.html. It says his wing are 2 feet> longer.> > Chris T.> Sacramento, CAThat URL is actually http://users.aol.com/bpabpa7315________ ... __________
Original Posted By: At7000ft(at)aol.com
There was a fellow on this list from South Africa who used to fly a piet with the wings extended quite abit because of an extra wide center section ( six feet if I remember right). He came to the list trying to figure out why the tail would stall before the wing making landing a very exciting manuver. He finally ended up crashing it. I believe he wasn't hurt too bad but we haven't heard from him since. And remember....when you tilt the seat back back you are moving the C/G of the pilots head and shoulders aft, something we need to be careful of. Bernie did all of the calculations and experimentation for us so that every thing works together....When you change something it almost always affects something else. And besides...it's so much faster and easier to follow the plans. Ed G. in chilly Florida>From: piet(at)pointdx.com>Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: Wingspan>Date: Sat, 6 Dec 2003 14:14:19 -0500>>>Does anyone have any experience/knowledge about building Piets with varying>wingspans? Seems to me that if one isn't going for speed, one may as well >go for>shorter takeoff rolls(?), shallower glide path(?), etc, and therefore maybe>extend the wings just a bit.>>Would this require any changes to the tail surfaces?>>-Mike B.>>Winterize your home with tips from MSN House & Home. http://special.msn.com/home/warmhome.ar ... __________
