Pietenpol-List: Don't need no stinkin shelf
Posted: Sun Jan 04, 2004 6:23 pm
Subject: Pietenpol-List: Don't need no stinkin shelfI am building a long fuselage Piet with a corvair engine and therefore don't believe I need the shelf in the upper front of the fuselage. I plan on using afull height firewall extending above the top longerons like Mike Cuy's in his video. Question is how to finish off the upper front of the fuselage. I am assuming I can just add triangular gussets to the inside top corners (like those shown on the plans at the bottom corners) and a horizontal cross brace (maybe 1" x 3/4") between the 2 (#1) front vertical struts just under thetop inside motor mount brackets. Anyone see any problems with this?ThanksRick Holland________________________________________________________________________________
